My t@g window came loose. Need help.
We’re a couple of weeks away from another long roadtrip with our tag and are in the middle of preparing our camper for our trip. I had the front window open yesterday when I noticed the top of the window looked uneven and after further inspection I found that the entire hinge mechanism had failed. A small link of “C” tubing that was glued to the actual window had let go and broke leaving about 2” of tubing still bonded to the window that acts as the window’s hinge. Here are some photos.
My question is, what’s the best course of action here? I noticed that whatever glue that was use before wasn’t spread evenly across the surface of the c-tubing which in my opinion is the reason for it’s failure. Since I have a couple of inches of the tubing still stuck to the window, I’ve got a template of sorts as of how to position and rebond the piece that came off. I’ve scraped the old glue off and sanded it smooth again and now wondering what bonding agent I should use to get this piece to stay put? Any suggestions would be appreciated!
  • Texas_Dave
    Texas_Dave Member Posts: 17
    Also, would this “c-tubing” and the window be considered acrylic or abs plastic? ...in order to figure out the best bonding agent.
  • BBsGarage
    BBsGarage Member Posts: 385
    Give NuCamp a call, I'm sure you will find them more than accommodating.
  • Texas_Dave
    Just talked to Elsie and she did fix me up. Seems the windows have this piece attached when they receive them to assemble to the camper so it's a vender issue to them. Elsie is simply sending me a replacement window since I'm still under warranty and I should have it in by Monday...and leave out Thursday for the mountains. Whew! Stress levels dropping as I type this! Thanks NuCamp!
  • Texas_Dave
    PS, I still want to know what it takes to bond these to pieces back together incase this happens in the field. I'll report back if I ever find out.
    If it is acrylic, then acetone is a good welding agent.
  • Texas_Dave
    LuckyJ, I used Weld On #16 last night and waiting to see if it sets properly. (if it is indeed acrylic). Report to come. My new window never came in so....:(
  • Texas_Dave
    Nothing like having to strap your window down in the rain the night before you leave for a 17 day road trip. I’m really frustrated at the moment.
  • therichards
    therichards Member Posts: 1
    Did you ever get a resolution on this issue? Did the Weld on 16 work? Same thing has happened to our T@g window except the rod didn't break, it just came unglued.
    Thanks. Brenda
  • rich67
    rich67 Member Posts: 166
    Likewise, would like to know what happened. Did you get the new window? We are on the road for a year, and this happened two months into our trip.
  • Sharon_is_SAM
    @rich67 - @Texas_Dave has not been active in over 3 years. Let’s see if he gets this notification.
