Tray that holds Fridge broken
dsarthur
dsarthur Member Posts: 12
I noticed that the back of the slide out try that holds the Nordic Cooler in my 2016 T@G has broken off. Has this happened to anyone and what what the fix?
  • BBsGarage
    BBsGarage Member Posts: 385
    Maybe a pic will help further describe where/how it has broken.
  • MrGGBrown
    MrGGBrown Member Posts: 42
    I just discovered that happened to our 2016 T@G also. Not sure if heavy braking, or just closing the slide-out with the Norcold full caused it. I used wood glue and 4 woodscrews to re-fasten it. It was originally only fastened with a power nailer, and possibly glue. I'm pretty sure it won't come loose again.
    Greg Brown
    Bellevue, WA
    2016 PVTT T@G
  • dsarthur
    Thanks so much. I will add a little glue and some wood screws. I was also thinking of putting some large velcro on the fridge and the tray to keep it still.
