Tray that holds Fridge broken
I noticed that the back of the slide out try that holds the Nordic Cooler in my 2016 T@G has broken off. Has this happened to anyone and what what the fix?
Maybe a pic will help further describe where/how it has broken.
I just discovered that happened to our 2016 T@G also. Not sure if heavy braking, or just closing the slide-out with the Norcold full caused it. I used wood glue and 4 woodscrews to re-fasten it. It was originally only fastened with a power nailer, and possibly glue. I'm pretty sure it won't come loose again.
Greg Brown
Bellevue, WA
2016 PVTT T@G -
Thanks so much. I will add a little glue and some wood screws. I was also thinking of putting some large velcro on the fridge and the tray to keep it still.
