I assume you want a door holder or door retailer or door catch.
This is the best I found on Amazon.
It may be the same as stock, but really I have not done the research.
Good Luck
Update on Door Stop Retaining Catch
I just replaced both of my door stops due to wear on my 2018 T@G 5 wide.
They were a perfect match and all that was needed was to remove and replace.
I used silicon sealant in the holes and screws for water protection and screw retention. (silicon is just an option)
A very easy fix. I would recommend
I don’t like the roughness of the stock ones and don’t wanna wear them out so I put the jhook of a bungee through one of the door handles holes and loop it around the trailer pull handles.
Any nucamp dealer, maybe any rv dealer as well.
Amazon - search RV door holder. Check etrailer, too.
I have one of these:
DW uses it for her paperback books and other items.
https://www.amazon.com/Map-Pocket-Lightweight-Retainer-High-end/dp/B005IEIPEG
Good Luck
@JamesDow tgis is also what I understand he was looking for.
A very easy fix.
I would recommend
