Wheel fender height
I'll be making a modification to my garage opening and needing to know what is the height of the wheel fenders on the 2021 tag XL boondock.
2021 NuCamp T@G XL Boondock π£
2012 Kia Sportageπ
Mine is 35" at 32 psi.
@zgfiredude How much higher would it be if the tires are at the recommended 50 psi?
2012 Kia Sportageπ
I would estimate not much, perhaps 1/2".....how are you modifying the opening? I wouldn't make the tolerances too small, the air pressure, front to rear level of the trailer, etc. can affect the exact height of the fenders.
I'm modifying the garage weather striping to be removable to allow clearance for the tires and fender as I push it in for storage. Single car garage measures in at about just under 96". So it'll be a tight squeeze. π
2012 Kia Sportageπ
Interesting......if the side to side is that tight, why make the vertical so tight? Just go with a reasonable measurement of say 40"?
That why I was looking the height of the fenders. But I think your right just go with 40" or more for tolerance. Thanks for your response.
2012 Kia Sportageπ
Yea, some random dimension that might make sense with the architecture or construction of the opening.....even like 48" as an even 1/2 of dimensional lumber?
- 2 nΓΌCamp & Forum Contacts
