Wheel fender height
I'll be making a modification to my garage opening and needing to know what is the height of the wheel fenders on the 2021 tag XL boondock.
2021 NuCamp T@G XL Boondock 🎣
2012 Kia SportageπŸš™
  • zgfiredude
    zgfiredude Member Posts: 215
    Mine is 35" at 32 psi.
  • royh210
    royh210 Member Posts: 22
    edited May 2021
    @zgfiredude How much higher would it be if the tires are at the recommended 50 psi?
  • zgfiredude
    I would estimate not much, perhaps 1/2".....how are you modifying the opening? I wouldn't make the tolerances too small, the air pressure, front to rear level of the trailer, etc. can affect the exact height of the fenders.
  • royh210
    I'm modifying the garage weather striping to be removable to allow clearance for the tires and fender as I push it in for storage. Single car garage measures in at about just under 96". So it'll be a tight squeeze. πŸ˜…
  • zgfiredude
    Interesting......if the side to side is that tight, why make the vertical so tight? Just go with a reasonable measurement of say 40"?
  • royh210
    That why I was looking the height of the fenders. But I think your right just go with 40" or more for tolerance. Thanks for your response.
  • zgfiredude
    Yea, some random dimension that might make sense with the architecture or construction of the opening.....even like 48" as an even 1/2 of dimensional lumber?
