Other Refrigerator?
Does anyone know of any other refrigerators besides the NRF 30 that will fit in a TAG ? Engel seems to make some really nice units that only draw .75 to 3.5 amps. Not sure it would fit in the TAG though... Looking for something that draws a few less amps and maybe is a little more reliable than the Norcold.
  • Sharon_is_SAM
    Look at an ARB. Draws on average o.7 to 2.3 amps.
  • jackmbernstein
    jackmbernstein Member Posts: 27
    I, and others, after looking at the Iceco JP 30. Depth only 13.8”, narrower than the yeti.
    2021 T@G named Amelia Pond
    2020 Mazda CX-5
    Englewood, OH
  • ClarkGriswold
    ClarkGriswold Member Posts: 34
    An ARB won't fit and the tops open lengthwise which would require a longer slide on our T@Gs even if it would fit. I had one in my prior TV and contemplated moving it to replace the Yeti... ended up just installing the Norcold that fit like a glove.
    2019 T@G 5W Boondock Edge
    2008 M-B G500
    Somewhere in the PNW
  • laurabe
    laurabe Member Posts: 7
    I heard an Engel is good. I have a 2020 Tag and am trying to figure out the answer to your same question too.
  • drsukie
    drsukie Member Posts: 47
    On the rec of a friend who bought one, I am getting this: **BougeRV 12 Volt Refrigerator **12V Car Fridge 30 Quart Portable Freezer Compressor Cooler Compressor Freezer,12/24V DC 110~240 Volt AC,-7℉~50℉ for Truck RV SUV - that's the Amazon detail 😊
  • UpNort
    UpNort Member Posts: 13
    If you have an older T@G as mine, 2014, the cooler space is slightly smaller. The Igoo ICF32 fits perfectly in the cabinet space with the slide out tray with no modifications. Its even 2 liters bigger capacity than the original Norcold. It can run on either 12V DC or 120V AC. Igloo was taken over by Dometic a few years ago, so I assume that's what your buying. I found it available at Dick's, Best Buy, Amazon ect.
  • ragtag2
    ragtag2 Member Posts: 73
    Our 2024 5 wide T@G (Boondock) has a Camco 12v cooler (about 30 liters). It's a little noisy, but some foam padding on the pull out tray has helped with the compressor start-up noise/vibration. Give me a few days to get back to where the trailer is parked and I can provide model number and dimensions...
    TV: Volvo XC-60 T8 R
