Propane Shower/Hot Water System
Just finishing up my latest mod. Propane shower system in a removable box mounted to my rig. The line tees off to a spray faucet (bidet faucet $20 Amazon) that can be attached to my dishwashing tubs for filling the tubs or using The sprayer to rinse. I had been hanging the propane shower in a tree and running a water line to it. Decided if that box ever flamed up, standing naked in a plastic shower enclosure, next to it and a flaming tree might be a bad idea. This way I direct connect to my water pump and just run the 3/8 line to wherever I hang my shower enclosure. Shower was $140, box was $80, hoses and fittings probably $40. The shower has been a welcome addition to our boondocking for a year or two. Now it’s just mounted and more compact.
T@G XL
2017 Jeep Rubicon Hardrock
Cool setup! How did you mount the box to the wall? Is it attached permanently?
2018 T@G XL
I got these slide on TV mounts on Amazon for $11 each. Liked that they were very low profile and have a screw on top if you want to attach it more permanently. My box as you see goes over that water fill. We only fill that once on a trip and otherwise use water from to 30 gallon tank I have mounted a small under the trailer for the shower system. That fill valve is in the rear bumper.
T@G XL
2017 Jeep Rubicon Hardrock -
Where did you get the black Condition 1 box?
I got that on Amazon. They have a ton of sizes and you can order direct from them as well. There are lots of similar boxes online but I was pretty fixated on as small a box as possible that fit my heater, and they had that size.
T@G XL
