Propane Shower/Hot Water System
Just finishing up my latest mod. Propane shower system in a removable box mounted to my rig. The line tees off to a spray faucet (bidet faucet $20 Amazon) that can be attached to my dishwashing tubs for filling the tubs or using The sprayer to rinse. I had been hanging the propane shower in a tree and running a water line to it. Decided if that box ever flamed up, standing naked in a plastic shower enclosure, next to it and a flaming tree might be a bad idea. This way I direct connect to my water pump and just run the 3/8 line to wherever I hang my shower enclosure. Shower was $140, box was $80, hoses and fittings probably $40. The shower has been a welcome addition to our boondocking for a year or two. Now it’s just mounted and more compact.
FA645158-E642-4D93-853D-420820E7348E.jpeg A7B18B40-3ABC-42D8-915A-1CD9AB8317BE.jpeg A640A2B2-28DD-4166-AF23-FD94A239CAA0.jpeg 3EDE1080-43D0-40C5-9FAB-11AA3898F93C.jpeg
T@G XL
2017 Jeep Rubicon Hardrock
  • Cool setup! How did you mount the box to the wall? Is it attached permanently?
    2018 T@G XL
  • I got these slide on TV mounts on Amazon for $11 each. Liked that they were very low profile and have a screw on top if you want to attach it more permanently. My box as you see goes over that water fill. We only fill that once on a trip and otherwise use water from to 30 gallon tank I have mounted a small under the trailer for the shower system. That fill valve is in the rear bumper.
    AA687F17-B7FB-4DB9-991C-775F89F93046.jpeg C47F033A-C574-4262-8E24-60E8059E8EE4.jpeg EFFEAB7E-0105-4EBD-A02E-5E85581D63FB.jpeg
    T@G XL
  • hidaven
    hidaven Posts: 1
    Where did you get the black Condition 1 box?
  • Hitech
    Hitech Posts: 38
    I got that on Amazon. They have a ton of sizes and you can order direct from them as well. There are lots of similar boxes online but I was pretty fixated on as small a box as possible that fit my heater, and they had that size.
    T@G XL
