2023 T@G XL Boondock - King Heater and GE AHEC05 Air Conditioner Specs
aBiNeR
aBiNeR Member Posts: 17
(Title edited for search purposes. Moderator)
Hey all!
I just scoured through the 2023 T@G owners manual but I couldn't find the info I was looking for. Maybe someone here might know?
First, does anyone know the power specs on the A/C and heater? I'm trying to calculate power usage but I can't find how much power these two devices consume.
Also, I found the following in the owners manual:
120V AC SHORE POWER
When connected to an external 120V outlet or generator via the 120V
shore power cord, your camper will be supplied with power. The electrical
system will be grounded via shore power if there is no open ground in the
supplying outlet or generator. The negative terminal on your battery serves
as a ground to your electrical system when shore power is disconnected.
The 120V electrical system provides power for:
• Air Conditioner (If equipped)
• Microwave
• Power Center/Converter
• 120V Receptacles
12V DC SYSTEM
When not connected to 120V AC shore power, the 12V system uses power
from the 12V (or dual 6V) battery(ies) onboard the camper and functions
much like the 12V system in your tow vehicle. When 120V AC shore power
nucamprv.com • Teardrop Trailers 39
is connected, current runs to the 12V power center via the converter and
provides power to the 12V appliances and features. The negative terminal
on your battery serves as a ground to your electrical system when shore
These components and appliances work off 12V power:
• Lights
• Water Pump
• TV (If equipped)
• Vent/Fan
• 12V Outlets
• Propane/CO Alarm
I noticed that the heater is not listed in either the 120V Shore Power section, or the 12V DC System section. Does anyone know which system the heater is mapped to?
Thanks in advance.
