Openings in the face of headboard for storage access
GulfCoastGulfCoast Member Posts: 109
edited May 2024 in Modifications & Upgrades
We'd like to be able to take advantage of the space behind the headboard for storage, while keeping the lid closed to accommodate the seven small bins we keep on top. We've ruled out sliding doors and hinged doors in the face of the headboard. We're thinking that two openings roughly 5" x 10" inches might be a simple and effective solution. The items we'd like to store are mostly lightweight and somewhat compressible, like paper towels, bath tissue, coats and jackets, laundry bag, and such. Similar cubbyholes are common on small boats and work well.
I'm wondering if anyone else has done something similar and has suggestions on hole size and location, edge trim, and how to make the cuts. I'm particularly interested in suggestions on how to make the cuts neatly. I have an innate caution about cutting into nicely finished woodwork without a good reason and some serious thought.
Thanks.
    OK, I am a little confused (or just behind the times)
    My stock headboard has sliding panels/doors, allowing me to access storage behind the headboard (1/2 at a time).
    Was this feature eliminated on newer models?
    ___________________________
    No, you're ahead of the times, or at least my times. The sliders weren't present on older models. Ours is a 2017. The entire headboard panel is one piece of 1/2" plywood.
    edited May 2024
    @GulfCoast
    Maybe try two 1" x 2" boards cut to length and two groves cut with a table saw (slider tracks).
    Clamp and glue the slider tracks to the inside of the headboard, after you cut out an opening section.
    Then make the sliding panel rails out of 1/8" or 1/4" hardboard (or something).
    Kind of like I did in my garage for my shelves. (You would want to finish nicer).
    Another option with somewhat less work would be to just buy the slider tracks.
    The extra storage space is nice.
    Would I go through the effort and risk?
    Maybe, but it would be work getting them to look good.
    Best of luck.
    ____________
