Inverter Fan Noise on a 2024 T@G XL
I just purchased a new T@G XL with the upgraded battery option and realized the factory added two screaming fans to help cool the Victron inverter. The inverter is mounted directly under your head when sleeping and sounds like a jet in the distance. I was wondering if anyone else has experienced this or is this a one-off?
It seems like an odd choice for a location to mount an inverter. It's loud enough that I cannot run the inverter at night, which sort of defeats the purpose to have A/C or heat if needed. Even on shore power, the inverter has to be on in order to use the 120V system since they don't provide a bypass switch. NuCamp support has no useful info or schematics on this "upgrade".
Thanks.
