Inside window separating-is this going to keep me from camping this weekend?
Fourman110Fourman110 Member Posts: 230
I just pulled my BoondockXL out  of storage (for the first time this year no less) and discovered that creamy colored inside window separated a bit.  It l9oks like it's just trim, but I thought I'd better check with the forum.  Any chance of damage (water leaks, damaging the window,etc) if I travel with it or do I need to d9 some type of emergency repair first?
  • UpNortUpNort Member Posts: 10
    That corner trim piece snaps off. Then you can tighten the screw. If the wall is broken out where fastener is, that's an easy repair with an epoxy. That is just for the shade and screen. You won't have any water leaks, but the mosquitos can get in that way.
