I was able to attach this car back seat molle panel to the back wall of my T@G XL. I used rubbing alcohol to wipe the wall then attached 2” Velcro, industrial strength strips (holds 10lbs). Five strips were cut length wise then placed on wall and panel to connect. The straps were removed with seam ripper and a little trim. There is also a deep pocket to stack things inside. One on bottom and one smaller on top that are integrated with the panel. Feeling so organized and happy!
