2016 Little Guy need model and weight
UncleStu
Member Posts: 7
Newbie here! Can anyone help me determine the unloaded weight and model name of this cute little teardrop we just purchased? She is 5 ft wide with AC, DVD player, and no battery shut off switch
AI OverviewThe 2016 Little Guy T@G teardrop trailer has several configurations, but a common model, the T@G XL Max, has specs including a dry weight of around 1,150-1,388 lbs, a length of about 13'7", and can sleep two people. Key features include a 2-inch ball mount hitch, 30-amp electrical service, and amenities like a kitchen area, and heating/cooling options. The T@G Basic is lighter, at about 995 lbs, with a slightly shorter length, and the T@G Max Basehas a dry weight of 1060 lbs and is about 163 inches long.Key specifications
Feature T@G Basic T@G XL Max T@G Max Base Sleeps 2 2 2 Length ~13 ft ~13 ft 7 in ~163 in Dry Weight ~995 lbs ~1,150 - 1,388 lbs ~1,060 lbs Hitch Weight ~90 lbs ~90 lbs ~100 lbs Hitch Ball Size 2 inch 2 inch N/A Electrical 30 amp shore power (requires generator or hookup) 30 amp N/A Fresh Water 5 gallons (rental) 5 gallons N/A
@UncleStu
Your 2016 T@G looks a lot like my Standard 2018.
I bought mine used in late 2018.
Put on around 21,000 miles with no major issues. Hope yours provides the same.
I find it odd the you have no battery shut off switch. I would view that as a must have. Cost for one is around $20.
I find it odd the you have no battery shut off switch. I would view that as a must have. Cost for one is around $20.Agreed. I need to add one so it’s easy to switch back and forth from 110AC to 12v.
Do you have a wire access hole and two screw holes in the center of the diamond plate? (See where my shut off is located)
JamesDow said:Do you have a wire access hole and two screw holes in the center of the diamond plate? (See where my shut off is located)
>>Nope. The only thing in that area is a mount for the gas line, maybe a pressure regulator
Per Google AI, "The 2016 T@G camper models may or may not have a factory-installed battery shutoff switch, as they began to be included mid-year in 2016."
So, this info tells me that my new rig is older than mid 2016. ThanksJamesDow said:Per Google AI, "The 2016 T@G camper models may or may not have a factory-installed battery shutoff switch, as they began to be included mid-year in 2016." -
Little guy released new models in April of the preceding year. Your 2016 model was probably built in the second half of 2015 and at that time, a battery switch was not included. The company frequently makes model changes mid- year.
Check the label on the front frame. It should note the build date.Sharon - Westlake, Ohio | 2017 TaB CSS -
Correct, it says 2015 on the VIN plate. Thanks!
