2021 Nucamp T@G - Galley Leak
Triton46
Member Posts: 27
I'm getting water pooling in the galley on the floor by the cabinet on the left-hand side. We camped out in rain twice this year and have not had a single leak.
What are some common leak points?
I sealed the top and sides of the rear license plate holder as well as drilled holes in the bottom of the license plate holder.
I suspect the rear left-handed side lock/latch.
One thing I noticed when it leaked was the parking position. The trailer is parked in a facility with a gravel lot. Our space is toward the back of the lot on an incline (nose down). After I discovered the leak and trying to figure out why it had just started, I decided to crank the nose up so the trailer was level. The facility recently put down fresh gravel so it's possible the incline was a bit steeper than in the past. We've had a few rains today for about an hour, so I went down to check. Dry! I'll hold off on declaring victory until we have a good rain, but this jives with our year of ownership and lots of rainy nights. Galley is always dry and the trailer is level where we're camping.
If this is the cause (stern was raised, bow declined). What would be the points of water entry I would investigate? It must be a pretty specific leak point to only occur when the bow is declined to a certain angle. -
Moderator, Could you move this thread to Service/Maintenance & Recall Notices?
I've spent some time at the lot investigating. The seels all seem tight. On the lower edge with a dollar bill shut in the galley seels, I'm unable to easily pull the dollar out. I have noticed that when shutting the galley, I can easily close the t-handle. When we first bought it, we would lean on the door while closing the t-handle and you could feel the drag of the the cam in the post.
I marked the current position of the cam, loosened the hex bolt and slid it a bit further up to pull the hatch in closer as it latches. We'll see how it it works!
The silver shows where the bottom of the latch was previously. I also ordered some plastic cam plates to replace the washers. Originally, each t-handle had one large washer and one tiny washer. The tiny washer was getting sucked into the hatch. What does everyone else have here on the back of the t-handle?
Note: I have nylon lock nuts but waiting for the plastic cam plate to arrive. These washers were a temporary fix.
My 2018 T@G has not experienced any galley leaks so far. No adjustments have been made on the latches. No modifications.
Did you add tape to the cam shaft? I could see that helping to prevent the cam from sliding.JamesDow said:My 2018 T@G has not experienced any galley leaks so far. No adjustments have been made on the latches. No modifications.
Well, I thought by getting the cam closer to the latch that would pull the galley door tighter on the seals and stop the leak. Today we had our first good downpour since the adjustment, although the water intrusion was less than previous rains, I still had water in the galley.
For reference, the water pools where the red triangle is located. The opposite side is dry. Opening the door after a heavy rain I find the sill plate (blue line) has standing water. It seems like that is how the water is getting into the hatch. I did test the seals in that area with a dollar bill and shut the door. The dollar does not move easily when pulled meaning the seals are tight.
When I adjusted the cam and replaced the bolts on the t-handle, I also cut some new gasket from 1/16" neoprene in case the old foam gasket were leaking.
Finally, found the leak! The trailer is parked at a decline toward the driver side. I poured water on the driver channel, t-handle latch and license plate and no water got into the galley. I poured water down the passenger side channel and water is getting into the galley through the seal on the bottom of the door or bottom of the hatch and traveling from passenger side to driver side then intruding in the corner.
I also found that the seals at the passenger-side lower hatch corner are partially loose:
The seal on the hatch door at the passenger-side lower corner is unglued by approximately 1–2 inches.
The seal on the passenger-side vertical hatch door at that corner is also unglued by approximately 1–2 inches.
I reached out to Nucamp for part numbers of both the hatch and door seals which may need to be replaced. I'm going to use some weather stripping adhesive first to see if that fixes the issue.
I believe the repair may be completed. I reattached the loose weatherstripping on the door with 3M Weatherstripping Adhesive then sealed the bottom edge of the door, where the water channels, with some Sika Pro Select sealant to divert it away from the weatherstripping.
I ran another test and I did not see water in the galley. I'm awaiting one more good rain before declaring victory. -
Unfortunately, the leak is still there. I'm not sure how it gets from one end to the other and will need to run more tests. For now, I have a 2" block under the driver's wheel to level it out.
