You know that emergency break cord..... I pulled it.
Fourman110Fourman110 Member Posts: 230
Putting the trailer away ahead of a storm, I found the emergency break cord on the ground. Looks like i got it caught up on the tounge wheel while rolling it into my garage.
I pushed the plastic break pin back into the housing. Anything else I need to do?
    You did the right thing. I did the same thing with the trailer break-away wire, quickly plugged it back in and all was well again. What you don't want to do is leave it out. It places 12 volts DC across the circuit that engages the brakes and if left in this condition it could heat up the wiring and damage the circuit and brakes.
