Cabinet and galley mods
I was inspired by others and put a shelf under the sink. I did not fully encapsulate the plumbing as every square inch in these units is of value. Put soft stuff near the plumbing to things keep working as advertised. Just need to keep in mind there might be heat from the burners after cooking that could make things more then interesting on the upper shelf. I used 1/2" plywood gorilla glue and a small staple gun for assembly, then simple L brackets to attached with 1/2 countersunk screws.
Also inspired by others. Great mod used just this past windy weekend so coffee and breakfast could be served.
Thank you all for your ideas. Necessity is the mother of invention!
«13
