How do I empty the water tank completely?
papa
papa Member Posts: 15
how do i get all the water out of the water tank
there is no bottom drain...
  • mgreen2
    mgreen2 Member Posts: 193
    Pull up the black T connection under the sink.
    Like he said, but you will not be able to empty it completely w/o lifting the front and tilting to the left the entire trailer.
  • Mahojin
    Mahojin Member Posts: 7
    I always leave open on return trip. Even long day drives. Dry as a bone when arrive.
    Jake & Mitsue. T@G Max "Red-Teddy" MN, Honda Pilot Touring
  • TomD
    TomD Member Posts: 357
    As usual the simplest solution is best.
  • mgreen2
    Was at the factory yesterday and the new T@Gs have a drain on the bottom of the water tank.
  • Jumper
    Jumper Member Posts: 70
    Thanks for that info.!
    I sure wish my new Tag would get delivered.
    Huh! Wonder if this could be retrofited! Interesting for sure.
    WilliamA Member Posts: 1,309
    I suspect that replacing the water tank would be an invasive process. Particularly with the bung in the bottom, which would require plotting the hole, drilling it and then hoping the triangulation is accurate. For those of us with the bung on the side it's more a matter of adjusting our various techniques to achieve the end result. Now that I've grown comfortable with the minor design foible, I can get along just fine with it.
