How do I empty the water tank completely?
how do i get all the water out of the water tank
there is no bottom drain...
Like he said, but you will not be able to empty it completely w/o lifting the front and tilting to the left the entire trailer.
I always leave open on return trip. Even long day drives. Dry as a bone when arrive.
Jake & Mitsue. T@G Max "Red-Teddy" MN, Honda Pilot Touring
As usual the simplest solution is best.
2012 Ford Edge Sport TV -
Was at the factory yesterday and the new T@Gs have a drain on the bottom of the water tank.
@mgreen2 said:
Was at the factory yesterday and the new T@Gs have a drain on the bottom of the water tank.Thanks for that info.!
I sure wish my new Tag would get delivered. -
@mgreen2 said:
Was at the factory yesterday and the new T@Gs have a drain on the bottom of the water tank.Huh! Wonder if this could be retrofited! Interesting for sure.
@mgreen2 said:
Was at the factory yesterday and the new T@Gs have a drain on the bottom of the water tank.I suspect that replacing the water tank would be an invasive process. Particularly with the bung in the bottom, which would require plotting the hole, drilling it and then hoping the triangulation is accurate. For those of us with the bung on the side it's more a matter of adjusting our various techniques to achieve the end result. Now that I've grown comfortable with the minor design foible, I can get along just fine with it.
