TaB forum updated address
Sharon_is_SAMSharon_is_SAM Member Posts: 696
edited March 2019 in T@B Forum
Just an FYI regarding a recent update.
I know that some of you are registered over on the TaB forum. Vanilla recently changed the URL and @Michigan_Mike updated your link to the TaB forum located under the TaG forum Categories. Just know that if you previously saved TaB forum discussion links, you will need to adjust the address in order to load them.
The address changed from “vanillaforums” to “vanillacommunity” - now uniform with the TaG forum address.
https://tab-rv.vanillacommunity.com/ or here
