DaveB
Member Posts: 101
Sometimes I get to play with some pretty cool machines at work. I work for a company that supplies industrial inkjet printers (the machines that put those date codes on everything you buy). Our product line also includes laser coders, so I decided to play with one and see if I could make a custom back lit acrylic sign to personalize our TD. I made the line drawing, reversed it and did a few test runs on some 1/4" acrylic we had laying around the shop.
I was rather impressed with the results so went ahead and made a little frame and added some LED strips, mounted the acrylic and LEDs to the frame with some good old hot melt glue and I think it turned out pretty darn cool. Below are pics of the various stages, the laser was an industrial grade class 4 60W CO2 laser and I was engraving about 1.5mm deep using 4ms pulses 100% power at a speed of 800mm/sec. it took approx. 1 minute to engrave the entire image. Also present for the process was a BOFA laser fume extractor (the laser literally vaporizes the acrylic and you don't want to breath in the fumes, not to mention the damage the smoke can cause to a very expensive lens).
It was a pretty fun and cool project I thought I'd share.
2020 T@G Boondock Edge XL
Great work
2017 Tag XL
