poliver
Member Posts: 32
I can’t seem to find much information regarding the rear propane quick disconnect located below the rear bumper on my T@G XL. I’m assuming it is low pressure???? If it is low pressure, can it be converted to high pressure?? Certainly would be handy for a fire pit or bbq.
Look in the front propane/battery box. If there is only one line coming from the tank, and one line from the regulator then it is regulated. If so then you can always add a splitter at the tank and run a new line down to the quick dicsonnect.
If you have a 2021 then it is designed for portable grill or stove
@poliver - email tech@nucamprv.com and someone should be able to help you.
Thanks for the input. I will contact NuCamp.
We were wondering the same thing...and try and find a hose. No one can get one. Everyone says next year.
If you can access the TaB forum, this discussion may be helpful:
https://tab-rv.vanillacommunity.com/discussion/comment/146034#Comment_146034
Go to a propane business, they can make any hose length, with any connector you like.
Amazon has them as well.
