Finally found a bike setup that works!
So after trying a bunch of different setups to haul my mountain bikes around, I finally go the setup I think I will be sticking with from this moment forward. I tried using the Jack-It for the bikes, but found because I had a 29er and two large frame bikes, a lot of times they were rubbing and damaging the forks, etc. during transit. I also wanted a solution to haul kayaks at the same time as the bikes. Now, I know I have a roof rack for the T@g, but I added a Thule rack to the hard top of my Jeep, so I could easily haul two kayaks on there, then still have the MTB's on the whole setup.
(Edited for photo size.)
So using a Swagman RV approved bike carrier (holds the bikes by the tires, which I prefer) with an extension tube, I managed to keep the whole thing away from my trailer jack and holds the bikes firmly without worry. Not to mention I can disconnect the trailer at the campsite and still have my bikes with me to go to the trailhead without any moving around. The Jackit was stuck to the trailer...not much good if you needed to drive to a riding point. I tried this setup the other week with the kayaks and the bikes, and it worked out perfectly. The only issue is lack of access to the rear hatch; I have to load everything through the backseat. No big deal; I have my Hi-Lift mounted back there anyway, and it interferes with loading regardless.
Awesome setup Rich!
2021 TAG XL Boondock
Toyota Tacoma
Evergreen State -
Thanks, I’ll take a picture of it once I’m loaded up tomorrow for my trip.
@rich67 ...Google "using a hitch extender while towing a trailer"... one reason we haven't carried bikes yet...
2018 Nissan Pathfinder -
Ontheroad, we examined the issue regarding the hitch extender. The Jeep has a max tongue weight of 350. The T@g with the LP has a tongue weight of 170. With two bikes and the rack, we are adding close to 85 more pounds. That’s roughly a 255 #. tongue weight. With half the max we would have stood at 175#, so we are exceeding the max (using those figures) by 80#. I made sure I bought the right equipment and made sure the trailer is properly balanced to minimize weight issues. Haven’t had any problems thus far. I may eat my words one day, but this was the best solution I have found.
Great looking set up. Pretty dang cool.
TV 2018 Mazda CX9 Signature -
I think this looks great and would solve some of my problems with hauling bikes, even without the trailer issue. Can you provide a link to the product? Thank you.
Reese and a few other hitch makers make a hitch that is 16 inches long. That would do away with the extender you have on there. Then you would not exceed the tongue weight. https://www.amazon.com/Reese-80232-Hidden-Hitch-Angle-Cut/dp/B004R39XIG/ref=sr_1_5?dchild=1&keywords=long+trailer+hitch&qid=1596556711&sr=8-5
I've towed my T@G offroad using an 18" hitch extender with no issues. Similar issue as others have had towing with a Wrangler. My tire swing held jerry cans inboard of my already large spare (37"x13.5") necessitating the long entender. I'm glad my new TV doesn't require the big extension although I'm still having to use an 8" one to clear the spare in the same location.
NuCamp is really missing the boat with their tongue design placing the jack so close to the coupler. I think the T@G and T@B would be better trailers overall if they ran tube fore to aft as a backbone. This project is on my short list... possibly this winter.
@rich67 How much did the wrap run you? It looks great.
2019 T@G 5W Boondock Edge
2008 M-B G500
Somewhere in the PNW"Why aren't we flying? Because getting there is half the fun. You know that."
It’s not a wrap. We ordered the custom color direct from Nucamp. Also requested no decals.
when I get home I will post links to it. Still out and about this week.
@rich67 said:
It’s not a wrap. We ordered the custom color direct from Nucamp. Also requested no decals.Very cool. I'll have to remember that when we eventually go to a larger model (inevitable).
2008 M-B G500
@RealHillary said:
I think this looks great and would solve some of my problems with hauling bikes, even without the trailer issue. Can you provide a link to the product? Thank you.https://www.amazon.com/Swagman-Traveler-XCS2-Towing-Bike/dp/B003YJK1PS/ref=sr_1_23?dchild=1&gclid=CjwKCAjwmrn5BRB2EiwAZgL9ovcFOpd1jqgxeIiZiOEN8qju5LAUXT_Lo5XXPf_JEBl2_u_LZkRLvxoCkaEQAvD_BwE&hvadid=193308834236&hvdev=c&hvlocphy=9012375&hvnetw=g&hvqmt=e&hvrand=1602533126414314751&hvtargid=kwd-308387323438&hydadcr=7931_9891214&keywords=swagman+2+bike+rv+bumper+rack&qid=1596895061&sr=8-23&tag=googhydr-20
That's the rack itself, which can attach directly to the hitch, provided it's got enough length to fit and clear your tow vehicle. Great rack, and can be lockable as well. -
that whole rig would look good on display at Bass Pro in Vegas
Hey BlueTAG, your idea about the 16” ball mount was great but unfortunately, it doesn’t fit (barely) with the Jeep’s spare tire. The bike mount Rich67 is using bumps the tire and won’t let the ball mount to far enough into the receiver to put the pin in. You can see where I made a scratch on the ball mount to see how far I was missing by. Great idea and I wish it would have worked!
Very cool. I've been looking for a solution such as this. well played.
- 194 Camping & Travel
- 72 Tips & Tricks
