Renogy Suitcase 100w?
Has anyone purchased the Renogy 100W suitcase kit (RNG-KIT-STLCSLW-100B-NC)? We ordered one through Amazon as an open box but does not seem to be in good condition, so back it will go. We are looking for a portable (light weight) 100W kit for our 2019 T@G. Your thoughts and/or recommendations are welcome on vendors and sizing. Do we need 100W or will 50W suffice? We have not (yet!) made any mods to our trailer, so whatever the base power requirements are is where we are now.
    WayneWWayneW Member Posts: 20
    We have a 2018 Boondock XL and the 100 watt Renogy suitcase with the stock 85 amp-hr lead-acid battery (soon to be replaced w a 100 a-hr group 27). I did remove the TV and we seldom use the stereo. Other than that it's pretty standard. We do have the Norcold fridge. I don't know if you have that or the Yeti cooler.
    We live in the northwest where sunny days cannot be relied on. The 100 watt suitcase has been great for us and has always met our needs. In full sun conditions (and without the Norcold) the 50 watt would probably suffice but we went a little bigger given our location.
    In our experience Renogy has been a good company to work with. They often have a discount for 10% or so. There prices are usually competitive with Amazon prices and I'd rather go directly to Renogy if I can.
    Good luck! It will be interesting to see what others have to say.
    CoddiwompleCoddiwomple Member Posts: 5
    Thank you for your input. We live in the Mid-Atlantic area and also do not have to luxury of the mostly sunny days as in the Southwest. Yes we have the norcold cooler. We love the idea of a suitcase because it is light and easy to pack. It came damaged with a circle rippled area in the middle of both panels so we thought it might be better to ask a bit more questions as we try to fix this problem. We just got off the phone with renogy and are working to figure out what to do next.
    You may wish to search this site "Renogy".
    I did the same as you, purchased from Amazon and had to return. Physical defect upon receipt. I turned around and bought directly from Renogy for cheaper price and free shipping.
    I almost got the feeling that items on Amazon might be seconds or returns.
    My 100 watt suitcase does the job just fine with my wet cell battery.
    I would suggest buying two 15 foot wire extensions and the SAE adapter.
    Be aware the when the unit is in the sun, it can get hot to the touch when you move it for achieving best sun collection.
    My suit case came with the 20 amp Voyager controller. I could add another 100 watt panel if inclined. (I am not).
    That was actually one of the questions we were wondering about. We ordered a 10amp Wander controller since the panel did not come with one. What are the real differences when it comes with the controller amp sizes?
    Calculate amps would be 100 w / 12 v = 8.33 amps
    Solar panels do not put out 12 volts, instead a range runnig say up to 14 or 15 volts.
    Your 10 amp converter could maybe control an additional 30 watt panel. However due to environmental factors, you need to factor in an additional 25%.
    A 20 amp controller could accomidate another 100 watt panel. The Voyager controller is water proof. I am not sure if the Wander controller is.
    Thank you SO much! That actually is a great explanation on how it works. You brought up another question for me - How do you add on an additional solar panel if we ever want to do that?
    Adding two together could be done by simply connecting two wires to each terminal of the controller. If that was impossible due to physical space constraints around the terminals, an adapter of some sort would be required to connect.
    You would need to connect the panels in parallel.
    If you have two panels with different output ratings, the maximum voltage for the system is determined by the panel with the lowest maximum rated voltage.
    rasras Member Posts: 175
    edited October 2020
    We purchased directly from Renogy the 100W Suitcase with a built in controller. Which we use to charge a 105 AH acid cell battery for boon docking. Works so well that I've stopped toting a small generator. I originally thought about adding flexible solar panels to our T@G, but the ability to move the panels into sunlight while the T@G is in shade tipped the scale. The suitcase fits nicely under the bed in our T@G. You'd almost think they designed it that way ; )
    Oops. It's the 100W suitcase with controller
    I have the 100 Watt with controller. I LOVE it. Exactly what I need to keep my fan and my Norcold going when I'm off grid. I got mine on an Amazon Prime Day deal a couple of years ago. I also recommend the extension cable and the adapter to reverse the polarization.
    Good call. We like to watch a movie or two before bedtime as well as running the fan and Norcold which is why I am looking at the 200W.
    Which adapter did you purchase SueBHunny? And did you plug that into a Zamp outlet?
    This is what I got for my 100 watt Renogy Suitcase.
    Remember you need two of the 15 foot extension cables.
    I plug in at the T@G SAE plug and simply reversed the wires at the battery.
    Remember for a small cost you can also purchase a cable for security. Thread it through the handle. I made mine, but should be able to adapt something as pictured.
    I also purchased a temperature sensor, since I camp in the hot desert often.
