Molos
Member Posts: 3
Hello everyone, we recently picked up our 2021 Boondock Tag and it has a propane quick connect under the back of the trailer. The tank has a regulator and our Weber Q has a regulator. So our question is does the regulator need to come off the grill in order to use the back hook up? If so we would rather get a grill without a regulator if anyone has any preferences so it would be dedicated to the camper.
Thank you
(Title changed for search purposes.)
Yes you need to remove the grills regulator...from what I understand there is a kit for the weber and blackstone grills.
https://teardrop-trailers.vanillacommunity.com/discussion/1020/rear-propane-quick-disconnect
https://teardrop-trailers.vanillacommunity.com/discussion/comment/8762#Comment_8762
https://teardrop-trailers.vanillacommunity.com/discussion/1000/propane-quick-connect-and-storage-strut-arm-help/p1?new=1
Thank you for the info, looking forward to many camping trips.
We purchased this from Amazon. No mods needed and it connects to Blackstone or Coleman.
MENSI 12FT Male/Female Quick-Connect RV Propane Extension Hose Compatible with Blackstone 17"/22" Griddles https://www.amazon.com/dp/B081VYGNDQ/ref=cm_sw_r_cp_api_i_4USMFbH07AJT3
Thank you, gearing up for an Western trip to Big Bend in February will get one.
Question: The 17" Blackstone griddle I'm thinking about purchasing operates at 12,500 BTU's. But the propane connection on the back of the T@G is rated at 10,000 BTU's. Does the griddle/grill get hot enough to properly cook under this situation?
Thanks in advance.
Verified: The 17" Blackstone table top griddle works just fine with the rear propane port on the 2023 T@G XL Boondock, when used with the following hose:
https://www.amazon.com/gp/product/B081VYGNDQ/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
Thank you!
Does anyone know if those adaptor hoses will work on the Kovea Scout burner that comes with Tembo Tusk's Scottle grill?
(assuming, of course, you also using the Scout's propane adaptor)
You will need to (carefully) remove the regulator on the underside of your grill.
Amazon has a kit with most of what you need to connect where the regulator was... look for key words: NQN propane hose, compatible with 1 lb portable appliance, 1/4" quick disconnect connect for RV to grill.
I hope this helps,
HB
TV: Volvo XC-60 T8 R
One key part was the 3/8" flare x 1/4" NPT male pipe
Be sure to do the soap bubble test on all connections!
Happy grilling,
HB
