Smartsolar charge controler location
Allgrainer
Member Posts: 2
Greetings! Just purchased a t@g boondock edge. Trying to set things up and I have discovered the Victron smartsolar charge controller has an app that shows the status of the system. Trying to connect it with Bluetooth and apparently there is a number on the unit I need to pair. Does anyone know where this thing is located? I can’t seem to find it. Thanks!
The default code is 000000. You can change it once you get logged in.
Thank you that worked perfect!
