Tongue jack wheel
From another thread this video: https://www.opuscamper.us/op15/
At 5:10 into the video describing the Opus15 you'll see the wheel on the tongue jack. Notice how the axle for the tongue jack wheels is about 6 inches off center from the tongue jack tube. Anybody know of a US source for such a wheel mount? Having the pivot point for the wheels off center would greatly help the wheel to castor rather than skip across the ground. e-trailer has an entire jack assembly with such a wheel mount, but I'd rather not add such a heavy jack to my T@G.
When I searched (Google) the information, it appears that "etailer.com" has the brand.
Thanks, but I'm looking for just the wheel mount part, not an entire jack.
We replaced our TaB jack wheel with a dual caster wheel and it made a big difference in our ability to move it on hard surfaces.
The key attribute I'm looking for is a wheel(s) that is/are displaced from the center-line of the jack tube. The "standard" wheel mount is so close to the pivot point that on anything other than a smooth surface the wheels skid sideways rather than castor. I've added wheels, added larger wheels, lubed and still have the problem. Mounts such as the one in the picture I posted would address this problem, but are as easy to find as unicorns.
It woukd be very easy to modify the original caster frame to have it the way you want. A metal shop or a friend or fa,ily member that work steel coukd mkdify yours in about 1/2 hour.
If you come my way, I would even do it for free. But I do think that it would take you a long time to come here. 😉
Thanks for the offer...if I was next door I'd bring over a 6 pack of beer (to share) and take you up on the offer. I've located some welders in the local area, but until the Covid thing settles down I just didn't want the interaction.
Great!
