Before starting up A/C
csonni
csonni Posts: 354
So, we have our new T@G and, before turning on the A/C (not that we’re even near needing it), is there anything one must do before? Not sure even if the A/C has ever been turned on as its new. Or maybe it’s all plug-n-go?
  • HikinMike
    HikinMike Posts: 400
    Once you are hooked up to electric, turn on the external fan switch located to the left of the AC unit. This vents out hot air once you start the actual AC unit. Then turn on the AC unit and adjust.
    JamesDow Posts: 749
    Be aware if the ambient temperature inside the T@G is cool (say less than 60 degrees), the actual AC may not kick in. The main AC fan will work, but no additional cooling.
  • ras
    ras Posts: 213
    Make sure your T@G is level from left to right and a half a bubble high in front. The water drain is at the back of the metal pan under the AC. If you have the front of the trailer lower than the back, the condensation won't drain properly, will build up and overflow inside the trailer.
  • HellFish
    HellFish Posts: 140
    The A/C unit is overpowered for the space it is cooling. Consequently, the A/C cools the air quickly, and when the set temp is reached, the compressor stops running. This means the A/C generally doesn't run long enough to dehumidify the air. Many folks (me included) report cold, but damp air as a result. The answer is to vent the space with open windows/roof vent while the A/C is running. How much is so variable...you have to find what works for your temp and outside humidity. It sounds counterintuitive (open windows while trying to cool), and it isn't energy efficient. To be honest, the cooling setup in the T@G is not its strong point. Good luck.
  • csonni
    csonni Posts: 354
    Great info and advice. I'll remember those posts when we start heating up. Thank you.
  • csonni
    csonni Posts: 354
    The first time we plugged in our trailer to shore power I could hear the slight sound of a fan at the side exterior vent and we had turned nothing on at that point. We checked the A/C fan switch and that was not on.
    LuckyJ Posts: 1,239
    The fan you are hearing is more than likely the fan from the power convertor, is it part or just behind the fuse panel, that is just under the right cowbell.
    It should stop when no 12 volts power is needed or when the bttery is top off.
  • ras
    ras Posts: 213
    My musician wife finds that inverter fan so annoying that we open the breaker for the inverter at night so she can sleep. I just take my hearing aid out,
