Cracked PVC on Hose Attachment
So I drained the pump of water before winter but forgot to drain the hose in the tube. Getting ready for first trip next weekend and found that water had frozen in the pvc that connects the hose to the tube that holds it and split/broke off. Any one know if the remnants of that pvc can be spun out of the tube or is it glued in there. Not sure how to attack this so any help appreciated.
Duh, exactly the same problem here. Did you figure out how to fix it?
I also failed to winterize the exterior wash station. Split in connector is obvious within the hose housing but I don't know how to remove that pipe section to evaluate how to replace it. Any updates?
You have to remove the entire housing and replace it. I did the same thing. Call nucamp to get the part number then call an authorized dealer to order. Pretty easy fix.
Here's what worked for me...
https://www.amazon.com/gp/product/B01LXB219R/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=12018 T@G Boondock XL
2013 Outback w/ Curt Echo Brake Controller -
That’s it.
