Fan and water pump not working
Neither the water pump nor the fan are working through battery or shore line power.
Any trouble shooting advice out there for these newbies?
    Fan, cover need to be open enough for a limit switch to close de circuit.
    Water pump, you have a switch to turn on.
    Is this is done, them check fuse panel.
    Every thing esle 12 volts is working??
  • Sternimoto
    Sternimoto Member Posts: 11
    Happy ending:
    Water pump needed a new fuse and fan needed to be repositioned. From vibration of travel, it had gotten in to a bad position too close to the screen clips. Once pushed back up into proper position, it worked! Strange quirk with the Nucamp fan.
    @Sternimoto were you traveling with the fan cover open, you should not, it shoukd even be lock while traveling if that was the case. The cover, if not protected by a big cover should not be open in travel, it could be riped off the TD.
