broken door glass
I have an older Signatour Biscayne teardrop camper. This week my dog dove thru the door breaking the bottom tinted window pane. Has anyone replaced glass similar to this? The bottom window only has metal on the top and the glass is curved on one corner.
  • mwest
    mwest Member Posts: 3
    It looks like the door hinges have rivets. Guess I'll have to drill them out and take the entire door to a glass shop, but for the life of me, I can't figure out how to get out or put in the panes of glass.
    Your trailer kind of look like a little guy. You might get a little more info 9n tye little guy forum. But maybe someone can help you here a well. 😊
    JamesDow Member Posts: 750
    If it was my trailer, I would be tempted to use plexiglass in place of the glass that was broken. Still need to know how to remove and insert.
  • mwest
    Thanks - I cut plexiglass to use as a template for the glass company. After I installed it to check the fit, I think it works just fine. The screen makes it almost match the tinted top window.
