2021 nucamp tag xl boondock Victron controller location and 20amp fuse location
jsunwalters
Member Posts: 4
I am troubleshooting an issue with my solar panel and need to know where the controller is so I can inspect the LED's. Also I suspect my problem is that 20am fuse is blown as I also had a fuse on my tow vehicle blown. Is the fuse in the battery compartment or somewhere else? Thanks.
It's in the area above the AC unit where the TV would be. Blue box.
I sent an email to Nucamp and they replied that it is in the cabinet above the air conditioner but behind the false wall that you have to remove to see it.
