2015 water fill unbearably slow
I just bought a 2015 T@G. Tried filling the tank to test everything and work out any kinks. I have the flap style fill port that pivots in the middle. I had to keep the water flow at a trickle to keep it from backing out the fill port. Is there something I am missing?
Do not know much about the 2015 T@G and its plumbing/water tank system, but I know that my 2017 fill faster when tilted nose down.
I picked up one of these fill tubes from Amazon. Best $9.00 Canadian I have spent in a while!!
I agree with @poliver. That's how I fill my 2015.
2012 Subaru Outback -
Open the faucet or uncap the hose hook up, as you fill to purge the air from the tank.
@DCN082162 said:
Open the faucet or uncap the hose hook up, as you fill to purge the air from the tank.On a 2015 don't open the faucet. It'll just run the water out of the tank as you fill because there's no water pump switch.
Thanks for the tips. I'll try opening everything to help it vent and lower the tongue and see if that helps. If not I'll try the fill tube thinger.
Also I do have a switch for the water pump.
