replacement for the little doo dad that holds the door open?
The little plastic latch on the outside of the door/outside wall of the camper that holds the door open...I need to replace those. Do these have to come from the factory, or can replacements be found elsewhere, specifically replacements that fit the current screw holes??
thanks!!
shelly
Here is a link to guide you to your solution.
Very easy changeout. Perfect match.
I used some silicon sealant on the screws when I reinserted them.
Helps to keep them in place and to keep things waterproof.https://teardrop-trailers.vanillacommunity.com/discussion/1374/replacing-door-holder
Thank you SO MUCH!! Really appreciate the assistance!! Take care!
Well, rats...I wasn't able to find the Kesoto latch referenced above on Amazon anymore, or anywhere else on the internet. I went to eTrailer and chatted with a rep, but he was not able to come up with anything with screw hole centers to match existing holes. If anyone out there has any other suggestions, I'll gladly take them!
Well, if you can not find on Amazon, I would look to ebay.
I noted multiple sellers.
Double check size.
Thanks very much!
