Stabilizer Drill Fitting.
ZenDog
Member Posts: 15
I’ve been looking for a fitting that will go on the end of my power drill that fits on the end of the stabilizer. Does anyone have any suggestions? I’ve looked at all kinds of things, but nothing seems to fit.
Thanks, Zen Dog
I use a 19mm deep socket (<$6) and ratchet handle. Socket can also be used for other things, such as wheel lug nuts, spare tire lowering, ...
I see no need to carry around a drill, worry about power source or recharging for the sake of saving 30-45 seconds each time you need to deploy two stabilizers.
If you really wanted to use a drill, then for $2.75 an adapter could be added to the mix.
