What fuses are supposed to be in a T@g Boondock?
I have a 2022 T@g Boondock that I bought brand new from a dealer in Poulsbo, WA. I now live in Anchorage, AK. Camper is 8 months old.
I have developed an issue with the water pump and went into the fuse box to see if a fuse was blown. The colors of the fuses don't match colors printed on the fuse box itself next to where each fuse is plugged in. I can't find what fuses are supposed to be there - I can't find a schematic (and the owner's manual isn't much help) so I don't know if this is correct. I've never had to change a fuse on this thing so I've never touched them before now.
Can anyone provide me with what fuses are supposed to be in the four slots in the fuse box, top to bottom? If this is a dumb question I'm sorry - I just truly don't know the answer, I don't know if what I'm looking at is what I think I'm looking at, and I can't find what fuses are meant to be there. It looks weird to me. Am I nuts LOL? If I am - it's okay to tell me so. =)=)
2022 T@g Boondock 5WTV: 2023 Subaru Outback Wilderness
  • Pup7
    Pup7 Member Posts: 14
    Could someone post a photo of the fuse box with the correct fuses in it? That would be a huge help.
    JamesDow Member Posts: 750
    This is from my 2018
    Standard 5-wide
  • Pup7
    Thank you! That's a huge help. :)
  • The_Rigger
    The_Rigger Member Posts: 204
    The colors printed on the PC board next to the fuses don't indicate what color fuse you should use; those are the WFCO wiring color code.
    The correct fuses are as follows, from the top down:
    1. 7.5A - Lights/Gas Solenoid/Stereo system
    2. 15A - DC/USB Outlets
    3. 7.5A - Vent & AC fans & Water Pump
    4. 20A - Converter power
    5. 30A - Battery Reverse Protection
