How many Amp Hours for Lithium Battery
I know this is a loaded question with several "usage" related options, but in it's simplest form, How many Amp Hour capacity did you choose when you went to Lithium?
How many Amp Hours for Lithium Battery 10 votes
50 AH
0%
100 AH
70%
SueBHunnyJamesDowJayAZTaganglachelThe_RiggerTheFamilyCampster 7 votes
200 AH
30%
LandpaddlerDamnedBritb407driver 3 votes
Other
0%
    JamesDow Member Posts: 750
    100 AH
    I originally went with 100Ah lithium. I am in process of doubling that amount with a self made power box. My box will include a Victron MPPT 100/30 solar controller and 400 watt inverter. The box can operate as a pass through to the T@G or each component can operate independently.
    Unfortunately my project ran across a set back when the battery would not charge. In process of replacement. The 100Ah will run my Norcold refrigerator for about 4 days without solar assist.
  • The_Rigger
    The_Rigger Member Posts: 204
    edited January 2024
    100 AH
    I also went with a 100Ah lithium cell to replace the 100Ah lead-acid lump without having to also replace the Victron box and/or upgrade to a more-bigger-more-expensiver power center (the lithium-enabled 30-amp WFCO was hard enough to justify). I'm considering the future long-term possibility of adding another 100Ah cell in parallel with the first one, but I want to finish tweaking the original system first, to determine if I really do need that much capacity.
  • anglachel
    anglachel Member Posts: 3
    100 AH
    I started with 100ah, worked great for weekend trips, anything to much linger and you'd need solar or shore power. Fit nicely in the front, didn't change the weight much, was a pretty simple upgrade.
    Then it broke and I had to send it back for warranty repair. When they shipped me a replacement back I got 2 100ah batteries, and then the next day I received 2 more.
    My wife said "let's install all of them!" Which counted as permission as far as I was concerned.
    It was a bit more of a project than just swapping out the lead acid battery... But I now have an absolutely excessive 5kwh of batteries in the t@g, 4x100ah batteries.
    Shore power is optional for us now**, if we are staying somewhere more than a week we'll put up the solar suitcases.
    **the stock charger that won't charge the lithium batteries up all the way anyhow.
