Need help with a slipped side window string on our 2021 T@G
The white string attached to the lower screen on the side window slipped off recently.  It's not broken, but looks like we need to slip it back over the small black bracket/runner in the lower right corner of the window opening.  Have tried a screwdriver and needle nosed plyers unsuccessfully.  Does anyone know of a specific tool or otherwise have advice to fix this?  Also, looking at the end of the string (in the event it needs to be tightened) in the upper right corner under the corner trim piece, we cannot tell what type of tool would allow release and retightening of the end of the string.  Thanks!
  • The_Rigger
    The_Rigger Member Posts: 204
    Have you looked in the "User Manual/PDF Files/Vides & Resources" subforum yet? There is a list of window shade stuff there, including restringing instructions that may prove useful.
  • Lynnie_Barry
    Lynnie_Barry Member Posts: 4
    Thanks Dave in Michigan!  We were not aware of the videos.  Watching a couple of the videos gave us the needed insight to remove and partially disassemble the window shade unit...Problem fixed!
