Fuse sizes in TAG XL
JDW
Member Posts: 24
In my 2021 TAG the water pump and roof power vent is on a 7.5 amp fuse... When the fan in on med speed and we use the water pump it tends to blow the fuse... Is 7.5 amp fuse the correct one?
That's what nüCamp says, but I think they've underrated the circuit; I believe it should be 10A, as the fan draws 4A by itself.
Thank's... what I thought also...
