Broken Norcold NRF30 - Watch the bumps
The Norcold fridge in my T@G isn’t working. Not even cooling down 1 degree. After some investigation I believe the compressor broke at the outlet tube leaving the compressor (inside the black thing you can see through the ventilation grills). My best guess is it took a jolt over a speed bump or pothole although I don’t remember any particularly jarring events. Anyway just a tip to others to possibly consider taking the bumps easy and if it were me again, I would probably move it into the car where it would see less bumps. But given my luck, I would probably drop it carrying it to the car to protect it
Here’s my troubleshooting for any future investigators
- Fridge was working fine then it was not - likely not a leak
- Everything electrically appears fine, no errorrs, fan runs, compressor runs
- Compressor tubes leaving and returning are not hot or cold, maybe barely warmer on the outlet
- No noise of gurgling Freon upon startup or shutdown - no compression happening, probably rules out a plugged capillary
So I guess that the tube leaving the compressor snapped off inside the compressor housing and is blowing compressed (heated) gas against the outlet thus it being a little warm at the exit tube.
It’s unfixable by a hobbyist repair man like me and probably cost prohibitive to be fixed by professionals. New ones are around $550 on Amazon.
Good news is a Yeti cooler fits in the spot perfectly (I can’t remember which one I got right now).
How old is the unit? There is a two year warranty. They are designed and built for how we us them in our trailers so bumps in the road should be covered.
