T@G 12V Fridge Shelf Size - OR, which Norcold cooler is installed?
Hey guys, I plan on picking up a 2018 T@G 5-Wide Boondock in a couple weeks (have to drive 6.5 hours to get it) - anyway, I wanted to see if someone could tell me how large the slide out is from wall to wall, and height from shelf surface to the bottom of the counter top?
Reason being, we will have some boondock/dry camp scenarios sometimes, and until I invest in more battery capacity, solar panels, generators, whatever, I thought it would be easy enough to just unload the Norcold and set a regular ice cooler in its place for those trips. They are typically only going to be 3-4 days round trip MAX so getting ice once or twice won't be a big deal - I just wanted to get a head start on seeing what would fit.
OR, quite simply, which Norcold cooler is in the trailer? The NRF30, 45, or 60? I have found that the Yeti Tundra 35 replaces the NRF30 perfectly and the Yeti Tundra 45 replaces the NRF45 perfectly.
Thanks for any help.
Yep, as to be the 30, cause it is about the same size as ou ARB 35
Most helpful. Thanks y'all
