Surge protector advice please
I have 2018 t@g max. I've read that I need a 30 to 50 surge protector. If you use one, what brand do use?
After doing a lot of looking I went with this - Progressive Industries Portable RV Surge Protector Portable EMS-PT30X RV Surge Protector. Yes it is pricey but cheaper than losing the electronics in our camper. So far it has worked like a charm when plugged in at home and our one time at a campground.
I, too, did a lot of research into the matter and I ended up with the same electrical management system tanda62 did. It also came with a 50 amp adapter.
Ed & Karen
2017 T@G Max XL
2018 Subaru Outback 3.6R -
What sold you on the EMS PT30X instead of another protector, such as the Progressive industries SSP-30XL?
When you compare the two the EMS provides more protection and the digital readout is a nicer way of knowing it is working properly as opposed to the "idiot lights" on the SSP. Never been a fan of lights when a gauge is available but that is just me and my car hobby self speaking.😊
^^^ This. There are more potential dangers lurking within a shore power pedestal than surges. I just wanted protection from them all.
Ed & Karen
2017 T@G Max XL
Thanks guys.
In getting ready for a major trip next summer with our new 2020 T@G Boondock XL Lite, can anyone recommend the proper surge protector for the T@G?
Agree, noobie and electrical dummy. Which surge protector, please.
@Butch - I moved your inquiry to this thread. I would also recommend the Progressive Industries EMS PT-30X. It really depends on where and how you camp. If you only boondock, then your needs are limited to maybe powering up at your house in which you may have more confidence. However, if you frequent campgrounds with less contemporary grid systems or limited maintenance, well, you need better protection. Low voltage is a big concern in hot climates and busy campgrounds and I understand that low voltage is not good for A/C units and other fine electronics.
$300! Can I buy “most” of the protection for 1/3 the cost? LOL
Just ordered one - thank you for the help!
I use the Progressive Industries EMS Sharon mentioned. Peace of mind is valuable.
Ed & Karen
2017 T@G Max XL
I would like the same outdoor protector with just 20 or 15 amp "standard" plug setup.
I have been unable to locate.
Sounds like a business opportunity.
@JamesDow - plug adapters work, but are bulky.
Surge Protection Plus - ...
I do very little camping hooked up to shore power. Mainly use solar.
Planning ahead for a cross county trip this summer in my 2018 T@G.
Power needs = Lights, Television, USB Charging, Fantastic-Vent Fan, Norcold Refrigerator, AC.
Max AC 120 volt draw around 7 amps.
I have never found use for the 30amp cord and instead go for an adapter to a good extension cord.
Do not anticipate staying at many campgrounds which offer shore power, but thinking of utilizing these items to assist in offering protection when hooked up to 120 volt.
Trying to keep it simple, multiuse, cost effective and light.
Routine: Test campground power supply before hookup, add surge protection and cover/protect things that may be exposed to water.
The same setup can be incorporated with my propane generator as the situation warrants. (when I carry the generator)
- 194 Camping & Travel
- 72 Tips & Tricks
