Outlet popped!
one outlet inside 2018 t@g xl on left side of head board popped as my ipad was playing for about 10 minutes... now the outlet does not work... the other outlet inside does work. lights work also...was on shore power with battery switch in off position
any suggestions what happened?
thanks
Sounds like the outlet shorted out, have you checked the fuses?
Is that the USB or 110v
Usb is a fuse, 110v would be a braker.
@LuckyJ said:
Is that the USB or 110vUsb is a fuse, 110v would be a braker.
fuse, breaker, penny, tin foil, whatever works.
I know, you know and I know that you know!
But not everybody knows the difference and some need the guidance.
My GF is very a very bright women but she is not the handy type at all. And with attention deficit disorder ( does that make sence in english, taking this from my french, sorry) even If I tell her once, I would have to say it again later.
And since I know she is not the only one like that, sometime, a little more detail is better.
