Autowbrake electric brake controller
Has anyone installed one of these units? (https://www.amazon.com/Autowbrake-Trailer-Mounted-Electric-Controller/dp/B007HGI9OO) Is there a diagram of the junction box wiring for the T@G boondock? This seems like a good solution as the unit mounts to the trailer and not the tow vehicle, allowing for multiple vehicles to tow the trailer. Since there is no unit mounted in the tow vehicle there is no need to cut into the vehicle wiring. I appreciate any feedback.
Thanks,
Do not know about the auto brakes, but it almost looks like you would not have a 7 pins connection, so no battery charging capacity. But I might be wrong, I do not know that brake system.
but this is how the junction box should be
From the front of the trailer
1= battery charge
2= Ground
3= left flasher
4= Parking ?
5= right flasher
6= Brakes controls ?
7 = reverse
Rear of trailer.Ok, I screw up, I am not sure of no 4 and 6, I forgot to right them down when I was trouble shouting my brake problems and I had gremlins in the box. Dang!
Someone over on the TaB forum uses the Autowbrake.
Thank you for the information, I will check out the T@B forum.
I recommend AutoWBrake easy to install and it work well, if you have questions contact support Carlton will help you out.
I've owned and used the Tekonsha Prodigy controller and it was a simple install and worked great for me.
i think i looked into this a while back... but they are more expensive then the Tekonsha RF model.. the install is also requires more work... but i am glad of more option with the right idea.. the controller to be attached to the trailer
