Fantastic Vent Manuel Lift Knob & Noise Issue
Dear all,
I just made my first camping out last week that was really good. I found two issues asking your help.
1. I found my vent lift knob not working after trying to forcefully twist to lower the cover. It doesn’t lift or lower the vent cover any more. Is it an easy fix to replace the knob part? I couldn’t find any discussion related to this. It doesn’t look a complicated issue, though.
2. I have another a bit annoying noise issue especially at night coming from the fusebox area. It seems the lousy fan noise is related to cooling efforts for the refrigerator. Is shutting off the refrigerator the only way to silence the noise? Any suggestion would be greatly appreciated.
Best,
Memphi@hn
Edited for picture size - please remember to resize your photos. Sharon
The noise is the cooling fan for the converter, any time it senses a marked increase in DC current draw the fan will come on to keep the converter from overheating. Switching off the fridge at night will reduce the number of times that happens or you can leave the fridge on and disconnect from shore power overnight and plug back in in the morning, that's what we do unless we need to run the A/C, but then you can't hear the converter fan anyway.
Is the knob stripped or frozen?
if you are plugged into shore power turn off the battery switch, the fan noise will not happen and you don't need to charge the battery beyond a certain point
@beaky said:
if you are plugged into shore power turn off the battery switch, the fan noise will not happen and you don't need to charge the battery beyond a certain pointEh, if he turn the batteriy off, I think that the fan will run steadily, since it need to transform ac into dc to run the fridge.
I would suggest to pull the plug from the shore power and run only on dc for the night. So the converter will not run.
As for the fan cover control nub. It is only a small screw in the center of the knob. Pull it down, you will see if it is broken.
This knob does not need strenght to make it work. What probably happen is that the lock was in the lock position, so the cover coulb not come down. You would simply have turn the lock knob some, and the cover would have come down.
Many of the thing that move in an RV are smal light lever and things. If you putt to much strengh on them w/o knowing what is happening, they might brake. They should work in an easily manner, if not, then step down, and analyse what is catching.
Have fun outhere!
I agree with LuckyJ. Disconnect the shore power at bed time. No converter fan noise. The batteries or battery should support you through the night. Fire it back up in the morning.
Thank you all! In my next camping (May), I will definitely try to disconnect the shore power at bed time and will report you.
Re vent knob issue, I think the thread was crushed. I ordered a knob part and will try to replace it. I hope that is not that cumbersome job.
Thank you all again!!
Disconneting the shore power idea worked perfectly! Thank y’all!
And I was glad I could fix something by myself:) The vent knob replacement was found at https://www.amazon.com/Atwood-K1140-09-Manual-Lift-Knob/dp/B00S4YBA4Y/ref=mp_s_a_1_1_sspa?keywords=atwood+knobs&qid=1558783946&s=gateway&sprefix=atwood+k&sr=8-1-spons&psc=1.
Best,
Memphi@hn
Ever solve the vent cover knob issue? Only time I’ve had trouble is when I’ve forgotten to adjust the unlock problem.
I’ve got a MaxxFan remote fan on the way ala WilliamA. Really hoping for a better quality and lower profile fan (low relative to the vent cover I’ve got on...
This:
https://us.v-cdn.net/6030201/uploads/editor/ej/yv1ukdhypi5q.jpegPerfect!
I had the same problem with my lift knob. It would not lift or lower the vent cover. Contacted Fantastic fan and they sent me out a new replacement at no coast (2 year warranty). Replacement was no problem, after I realized that the broken knob and expanded some and would not easily fit back through the housing hole.
In a pinch I found that a 1/4 inch drive - 7mm deep socket worked as a replacement knob. ($1.98 at home depot). Good to have in the toolbox in the event the problem resurfaces.
