T@G 5 wide suspension
I dropped the trailer off today to have the suspension changed to Timbren axel-less. Looking for improvement driving down dirt roads as the trailer bounces a lot with the stock set up. Once I get it back, I will post my impressions and some detail.
Can't wait to read the results! I'll be looking forward to it. Please post a bit of detail or a link to the specific kit you are having installed. Some of us are drooling....
I will be watching this.
I should began working on my air bag set-up this week. I will have a lot of think to do. Cause I want it to be reversible if need be. At least at first. But the old axle will be use on a small flat bed utility trailer. With a 2200 lbs axle and brakes, it will be perfect for my area.
But yes, please post pics, and curious if you will have a higher stance with the timbren.
Btw, did you think about a longer modified tongue, instead of a longer hitch bar. It sure create a lot of extra stress on you LJ bumper and frame ends.
Just a tought.
"Btw, did you think about a longer modified tongue, instead of a longer hitch bar." Good point. I did look into a longer tongue with a max coupler hitch but that totaled over $900 so I just went with the hitch extension.
@Tonopah How did your Timbren change work out?
@Tonopah so, curious about your impression and how it was done on thst timbren axel less suspension. 😉
