Costco to pick up a couple 6V or Amazon for a 100 AH AGM
Planning on replacing the battery that came with our 2018 TAG Boondock. Want to be able to run the fridge longer between charges with the generator. Not sure which way to go. Looks like they would be similar in $. I think the AGM would be lighter. Any suggestions? Lithium is a long ways off for me.
One thing you might consider is installing two 6-volt golf cart batteries. It’s pretty simple to wire them together and will provide you with more amp hours. The issue or concern is space, and whether you can fit them into your trailer. Try doing a search of the forum area too as there is a wealth of information and tips to be gleaned here as well.
I am thrilled with my dual 6V GC battery upgrade. They are heavy though.
