Headboard / shelf
When we purchased our used (Very Little) 2017 T@G XL the previous owner had the dealer remove the headboard package. The parts were all there. I found it a hassle to reassemble. We now have a body pillow/bolster at the front. I was thinking about installing the former lid/shelf above as shelf alone. I would modify a bit with a lip to keep whatever from rolling off.
Question is, Any ideas how one should attach or just forget?
TV 2018 Mazda CX9 Signature
  • tagurit
    tagurit Member Posts: 179
    If you can locate where the original support for the shelf was screwed to the front wall, I imagine you could mount some shelf brackets. You might have to modify them a bit because of the radius of the wall but it could be done. I would measure where the mounting points are on our 2017 but we have a 5 wide.
  • GigHarborTom
    Thanks, can do
  • GigHarborTom
    Was all set up, and honey said "let's not".
    It is her baby.
