2019 T@G Base Model
JPRolandJPRoland Member Posts: 3
Is $10,500 a good price for a barely used 2019 Base model T@G? I own a T@B but have an opportunity to pick up a T@G and help out a friend. This is not the XL it is the 5' wide model. It looks real slick with blue trim and blue fenders. Thank you for answering.
    I purchased a used 2018 T@G Max 5-Wide (base model) in late 2018 for $11,000. Mine was used seldom, in good shape with no significant issues.
    Below is a photo of my unit as I drove it home 400 miles from the San Francisco Bay area. Besides some photos, I had not seen the trailer in person.
    In my opinion a price of $10,500 is very good.
    Good luck.
  • JPRolandJPRoland Member Posts: 3
    Thanks, James. I'll take a look at it tomorrow.
    I would agree with James on the good price......anything that hits the general camper market sells quickly and for too much money these days. I'd jump on that opportunity.
    F.Y.I.
    Two minor correctable items I encountered upon purchase.
    Water access side door would not unlock - Solved easily by using graphite
    Water pump would not prime - Took apart and manually primed.
    After a bit, I also unscrewed the overhead speakers and dumped debris from trailer construction. Sound of the speakers got better, but will never be great.
    At some point, I also replaced the two USB outlet ports because they were not functioning correctly. Again, a cheap fix.
    F.Y.I. the 2018 Max came with the stargazer window, audio system, Television, Refrigerator, Air Conditioning. I beleve the 2019 base also came with the same.
    I replaced the stock battery after about a year and a half.
    Replaced with a CostCo Group 24 marine battery $78.99.
    I just very recently replaced that marine battery with a 12V 100Ah Smart Lithium Iron Phosphate Battery.
    Good Luck
    Well, I'm passing on the T@G for now as she doesn't have her title in hand, yet. We'll see.
